Hello!
I have a Sabertooth X79 (LGA2011 socket) which I will replace with an Asus Z490 motherboaard (LGA1200 socket).
Does anyone know if the same cooler will fit on the new board???
Thanks a lot in advance!
Hello pammo45,
After checking the manual and specifications for Intel® Thermal Solution BXRTS2011LC we can determine that the supported sockets for this cooling are:
1. LGA1155
2. LGA1156
3. LGA1366
4. LGA2011 and LGA2011-v3
In case that you would like to confirm that information you please check the following link.
That being said, I would strongly recommend checking with the motherboard manufacturer for a list of all validated cooling solutions that will work with the motherboard specific model.
I hope this helps.
Esteban D.
Intel Technical Support Technician
Hello and thanks for responding!
I thought the physical surfaces of the LGA2011 and the LGA1200 were not so unlike, and that the cooler therefore maybe could fit both.
I also have an unused Noctua NH-L9i cooler (fan only) with "Socket compatibility Intel LGA115x" printed on the box. In an updated compatibility list I now find both LGA 2011 and LGA 1200.
I am going to use the i7-10700KF CPU without overclocking so maybe the Noctua cooler will do the job!
The idea of using BXRTS2011LC was that it is mounted on the old Sabertooth X79 mothterboard that I now am going to replace. It is eight years old, so maybe it's not a good idea to use it after all!?
I will also check the motheboard manufacturer's list of validated cooling solutions!
Thanks again!
Hello pammo45,
Thank you for your response.
I understand, I might be true that some sockets are similar, however, checking with them would be the best thing to do. In that way we are ensuring top performance and compatibility.
I really hope that you are able to find the appropriate cooling solution after checking their compatibility list.
That being said, f you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
