Running my PC on idle and found that I have high ram utilization.
I checked the task manager and found out that Intel Connectivity Network Service has high memory usage.
I am not sure if what is the apps used by this service. How should i fix it?
maximuseros665, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the Intel® processors?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
What is the model of the memory RAM? Please provide the quantity stick, voltage, and speed of the modules.
Was it working fine before?
When did the issue with the memory RAM start?
Did you make any recent hardware/software changes that might cause this issue?
Which Windows* version are you using?
Albert R.
CPU - Ci5-1245U
MB - Lenovo
RAM - 8GB
I just found the high memory usage since I stay my laptop on idle mode overnigiht.
I am using Win11 Pro
maximuseros665, Thank you very much for providing that information.
Albert R.
Hello maximuseros665, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello maximuseros665, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
