Processors
13841 Discussions
Intel Core i5 4460 Проблема с установкой драйверов
ДЧурс
Добрый день, столкнулся с проблемой по установке драйверов для процессора Core I5 4460 3.20 GHz, при установке любого ПО от Intel программа пишет что система не удовлетворяет минимальным системным требованиям:
Моя система: Core I5 4460, Windows 10 64 bit, Motherboard; MSI H81M-P33 , 16 GB RAM, ГП: Nvidia Gforce 970 4Gb 1TB HDD, если можете помочь то буду очень благодарен.
LeonWaksman
What is your computer/laptop model?
Leon
ДЧурс
what you mean computer model? PC
ДЧурс
My system; Windows 10, Motherboard; MSI H81M-P33
n_scott_pearson
Super User Retired Employee
Al is asking who makes your system and motherboard and what the model numbers are.
Are you trying to install an Intel HD Graphics driver package? When you install an add-in graphics card (like your NVIDIA GeForce 970), the BIOS, by default, automatically disables the Intel HD Graphics engine. If the engine is disabled, the driver package will fail to install. If you want BOTH the Intel HD Graphics engine and the NVIDIA GeForce 970 to be enabled and available, you need to go into BIOS Setup and modify the configuration to leave the Intel HD Graphics engine enabled regardless of whether an add-in card is present. Once you have done this and booted into Windows, you should be able to install this driver package.
Hope this helps,
ДЧурс
ДЧурс
n_scott_pearson
What doesn't work? Be at least somewhat verbose in your explanation.
ДЧурс
AlHill
Actually, it was Leon.
Doc
n_scott_pearson
So it is...
