Processors
14526 Discussions
Intel Core i5-6500 and DDR-4 2666 MHz memory (4 modules)
RTsoy
Can system with Intel Core i5-6500 works with DDR-4 2666 MHz memory (4 modules) onboard?
2 modules work fine (dual channel mode), but 4 modules don't work...
EstebanA_C_Intel
Hello romantsoy:
Thank you for contacting the Intel® Communities.
I would like to provide you with the compatible RAM for your Intel® Core™ i5-6500 Processor.
**DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V
Any RAM modules within those specs, should work with the unit.
Have you tried testing each RAM module in each DIMM slot? To discard either the RAM module or DIMM slot as the issue.
Esteban C
EstebanA_C_Intel
Hello romantsoy:
Esteban C
RTsoy
EstebanA_C_Intel
Hello:
I am glad to hear you got compatible module(s), do not hesitate to contact us back if you encounter with any additional or new inquiries.
Esteban C
