Intel Core i5 CPU 650@3.20GHz on ASUS P7P55D-E LX and problem using with Win7 64-bit with RAM selected. I purchased the following Corsair DDR3 1600 MHz RAM. According to ASUS the RAM should work fine, but there is a problem I found out about. The RAM worked till I updated my System BIOS. ASUS says it isn't compatible with the processor. How do I get RAM that will work properly with both my motherboard, and my Intel CPU referred to at beginning of message?
The Intel® Core i5-650 supports memory up to 1333 MHz at 1.5 volts.
http://ark.intel.com/products/43546/Intel-Core-i5-650-Processor-4M-Cache-3_20-GHz http://ark.intel.com/products/43546/Intel-Core-i5-650-Processor-4M-Cache-3_20-GHz
