Community
cancel
Showing results for
Search instead for
Did you mean:
sonnek89
Intel® Core™ i7-6700K one core is on average 20k higher than the others
Hello everbody,
im currently using the following system:
  • i7-6700k + Corsaire H100i water cooling with 2 fans
  • Asus Z170 Pro Gaming
  • 16gb HyperX Fury DDR4-2666mhz
  • MSI GTX 970
  • 600W be Qu!et PSU
  • Windows 10 pro
I have reassembled the PC and the following problem:
One of the CPU cores is on average 20k higher than the others. Sometimes I can even see in the temperature software that the temperature of this core suddenly jumps to 70° or higher and back again.
During the Intel test software run the other three cores run at 55-60° only the one goes above 80°. According to the test result, everything seems to be fine.
I guess it is a measurement error, is there any way to fix it?
I have checked the cooler and the thermal paste.
I have already updated the BIOS.
I am happy about ideas
AlHill
Incorrectly installed cooling system.
