Hello everbody,
im currently using the following system:
- i7-6700k + Corsaire H100i water cooling with 2 fans
- Asus Z170 Pro Gaming
- 16gb HyperX Fury DDR4-2666mhz
- MSI GTX 970
- 600W be Qu!et PSU
- Windows 10 pro
I have reassembled the PC and the following problem:
One of the CPU cores is on average 20k higher than the others. Sometimes I can even see in the temperature software that the temperature of this core suddenly jumps to 70° or higher and back again.
During the Intel test software run the other three cores run at 55-60° only the one goes above 80°. According to the test result, everything seems to be fine.
I guess it is a measurement error, is there any way to fix it?
I have checked the cooler and the thermal paste.
I have already updated the BIOS.
I am happy about ideas
Incorrectly installed cooling system.
