Hi
I have dell precision t3650. with Intel® Core™ i9-11900K, In system managment i've chose Technology Intel® Management Engine off.
Can I turn on Vpro in this case?
No, you cannot. A significant portion of the vPro functionality is hosted by the ME and vPro simply does not work without the ME running. vPro can be enabled only when a vPro-compatible processor is combined with a vPro-capable chipset and, in this context, vPro-capable chipset means one with the vPro components running on the ME.
Let me just add, AFAIAC you should *never* turn the ME off. In addition to things like vPro support, other capabilities - like DRM support - are also running on the ME.
