Processors
13546 Discussions
Intel Core i9-12900K clock watchdog timeout error
Sukrut4778
Specs -
Asus ROG STRIX Z690-E GAMING WIFI MB
64GB RAM
Asus ROG RYUJIN II 360 AIO (newly thermal paste applied)
ROG THOR 1200 PSU
I keep getting clock watchdog timeout error.
I have tried multiple things
1) In BIOS i tested using ASUS AI(both P Core and E Core)
2) Tested using sync all cores P Core - 52 and 51 / E core 39
I tested these settings and got same error in CinebenchR23/Prime95/IntelXTU
So i tried Intel Processor Diagnostic Tool and it also restarts while Prime number testing please help
Steven_Intel
Hello Sukrut4778,
At this moment, the 12th generation processors fail when testing with Intel® Processor Diagnostic Tool. We apologize for the inconvenience.
In order to better assist you, could you please provide a screenshot/picture of the XTU configuration and of the error?
Steven G.
Sukrut4778
Voltage is set to Auto no changes there.
Steven_Intel
Thank you for your response.
In order to work on this issue, please provide the following information:
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Sukrut4778
It happens when system is on heavy loads.
Steven_Intel
Thank you for the information.
I will work on this issue, as soon as I have an udpate, I will let you know.
Steven G.
Steven_Intel
Hello Sukrut4778,
I've noticed you have the RAM speed running at 5200 MHz, which is over the processor specifications (DDR5 4800 MHz - DDR4 3200 MHz). In order to continue, please set the RAM speed under the processor specifications (4800 MHz or less) and check if the issue persists.
When one uses an XMP profile, it changes the frequencies and possibly the voltages, which are internal to the CPU. Thus, it voids the warranty. It voids warranty even if the cores are not overclocked.
Please let me know of the outcome.
Steven G.
Sukrut4778
It did not work. i tried 4800MHz and still giving clocl watchdog timeout error on heavy loads
Steven_Intel
In order to keep working on this issue, could you please confirm when the issue started to happen? Was there any hardware or software change/upgrade before it started, or anything that could have triggered it?
Steven G.
Sukrut4778
It started happening in March - April and there was no hardware or software change. I thought it was thermal issue so i reapplied the thermal paste and still it did not change anything so recently in June I bought this new Asus ROG RYUJIN II 360 AIO and still it's giving the same error (Testing done at full fan/aio pump speed)
Steven_Intel
We are going to work on this issue, as soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello Sukrut4778,
Based on our investigation and information provided, it is very possible the processor was already affected by the RAM speed running over the processor's specifications. That is why we always recommend setting a speed according to maximum speed supported by the processor, since it is not sure if it will damage it.
Please let me know if you have any concerns.
Steven G.
Steven_Intel
Let us know if you have any concerns.
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
MCore1
The DPC Watchdog Violation error can be instantly fixed by updating the SATA AHCI Controller. To apply this fix, simply follow these simple steps.
To open the Run window, press Windows key + R. Type devmgmt.msc into the window and click OK.
run the device manager command line
Double-click the IDE ATA/ATAPI Controllers category in Device Manager to expand it. SATA AHCI Controller can be found here.
By updating the sata ahci controller, you can resolve the dpc watchdog violation error.
Choose Properties by performing a right-click on the SATA AHCI Controller.
Click the Driver tab and then Driver Details. See if the iaStorA.sys driver is listed here. If so, move on to the following action.
check for iastorA.sys driver
Clicking OK closes the Properties window.
Revisit the SATA AHCI Controller in the context menu and select Update driver.
To find driver software on my computer, click Browse.
Select Let me choose from a list of device drivers on my computer from the next menu.
select a driver from a list of those that are available on my computer.
Press Next after selecting Standard SATA AHCI Controller.
deciding on a standard sata ahci controller
