Processors
13875 Discussions
Intel DSA Website not working
DTurner618
I was asked to start a new thread on this topic. The DSA website only shows Sorry, something went wrong while trying to scan. I have fully uninstalled the client, re-installed using the latest version. I have the same issue with multiple computers and on different networks. Please see the attached files provided for support. This issue has persisted approx. 2-2/12 weeks now.
Sebastian_M_Intel
Hello DTurner618,
Thank you for posting on the Intel® communities.
Please confirm the following:
1. Have you tried using the other validated browsers? I.e. Chrome, Firefox, or Edge* (version 44.17763/18.17763 or newer browsers).
2. When you fully reinstalled the Intel® Driver & Support Assistant (Intel® DSA) did you do it from Apps and Features as well as using the Uninstaller tool?
3. After using the uninstaller tool, can you also provide this tool's logs?
  • Press Windows key + E (File explorer Windows will be opened with this key combination).
  • Click on "This PC."
  • Look for: Disk C:\, on the search bar, type: "DSAUninstaller.log".
  • Take the logs, copy and paste them into a folder and send them to us.
4. Do you remember making any changes that could have caused this issue?
Sebastian M
Intel Customer Support Technician
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Sebastian_M_Intel
Hello DTurner618,
Sebastian M
DTurner618
Thank you for your response. I have found the solution after reading your response. The issue was caused by my browser. I am using the Brave browser powered by Chrome. There is a security feature called "Shield" that is enabled on every site by default. Once I disabled this setting the site was able to load normally. Thank you again for your help!
Sebastian_M_Intel
Hello DTurner618,
Thank you for your update.
I am glad to hear that now the Intel® DSA is working fine.
We will proceed to close this inquiry, if you have any additional questions, please submit a new thread and we will be more than glad to help you.
Sebastian M
