Processors
14516 Discussions
Intel Driver & Support Assistant is not working
enzodsqdqs
hi i wanted to dowload some pilots for my pc but my Intel Driver & Support Assistant is not working i dont know why i downloaded the latest version of intel driver assistant by nothing and of course i tryed to unistall and redownload but nothing
and when I reload the page it doesn't work
here is my processor i5-3470S 2.90ghz
and i dont have gpu
please help me
DeividA_Intel
Hello enzodsqdqs,
In order to help you further, I will appreciate it if you provide the following information:
1. What do you mean by not working? Is it not scanning, is it not downloading the updates? Any error message?
2. After using the Intel® Driver & Support Assistant (Intel® DSA) uninstaller, did you check the "Apps & Features" to confirm that it was completely deleted?
3. Can you try any other browser (Firefox or Edge)?
4. Logs from the Intel® Driver & Support Assistant (Intel® DSA):
- log files can be found at C:\ProgramData\Intel\DSA.
Deivid A.
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
enzodsqdqs
hi thank you to respond
below u can see the text has wanted
DeividA_Intel
Hello enzodsqdqs,
I would like to let you know that your Intel® Core™ i5-3470S Processor is discontinued and Intel does not provide support for this product as well as new drivers.
However, I will help you only with the issue related to the Intel® Driver & Support Assistant (Intel® DSA). In order to better assist you, please provide the following:
1. Was Intel® Driver & Support Assistant (Intel® DSA) working properly before?
2. Did you use the Intel® Driver & Support Assistant (Intel® DSA) uninstaller?
- Uninstaller: https://downloadcenter.intel.com/download/30496?v=t
- Tool: https://downloadcenter.intel.com/download/28425
3. Are you using a supported browser (Firefox, Chrome, or Edge)?
4. You can see more information at the following link:
- https://www.intel.com/content/www/us/en/support/articles/000026895/software/software-applications.html
Deivid A.
DeividA_Intel
Hello enzodsqdqs,
Were you able to check the previous post? Please let me know if you need more assistance.
Deivid A.
enzodsqdqs
hi thank you for your respond
1 so yes intel dsa worked before
2 i used dsa installer
3 i use google
DeividA_Intel
Hello enzodsqdqs,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello enzodsqdqs,
Deivid A.
enzodsqdqs
ok
a lot of compliment for you Deivid
the problem was the browser. im actually using Brave so it block some features
and i move to edge and dsa scan worked
thank you a lot man
DeividA_Intel
Hello enzodsqdqs,
I am glad to hear that the issue was fixed by changing the browser (Edge), I will proceed to close this thread, however, do not hesitate to create a new one if you need further assistance with our products.
Deivid A.
