I have an Intel® Pentium® CPU G3240 @ 3.10GHz. I wanted to see if there was an update for the driver so I downloaded the Intel® Driver & Support Assistant. When I used it, it detected my processor as Intel® Pentium® CPU G3240 @ 3.10GHz and showed the driver I could download.
The problem is it shows Intel® Graphics Driver for Braswell, 4th and 5th generations.
But in the products page for the same processor shows
I don't know what to do, should I just download it, as the Driver & Support Assistant says or did it give me the wrong option? What should I do?
- Tags:
- Braswell
- Braswell and Haswell
- driver
- G3240
- Haswell
- Intel® Driver & Support Assistant
- Intel® HD Graphics for 4th Generation Intel® Processors
- Intel® Pentium® CPU G3240 @ 3.10GHz
- Intel® Pentium® Processor G Series
- pentium
- Processor Graphics
- Products formerly Haswell
You have edited 11 times in 30 minutes. Maybe you could wait and give someone a chance to answer.
sorry for that. I was trying to display the text below the images. for some reason I can't fix it.
It looks very disorganized right now.
I am new to this.
This is your processor:
This is listed as the latest/last driver for your processor graphics.
Ignore IDSA and use the link above.
does that mean the driver assistant showed the wrong information
I do not know, as I cannot read your pastes, and I do not use IDSA.
Use the links provided by ark for your processor and graphics.
