Processors
16438 Discussions
Intel Driver & Support Assistant
Eugenens
For some time now and numerous attempts later, every time I initiate the driver update process, I am informed that my Intel Driver & Support assistant is outdated and an automatic process begins to install the updated assistant. Halfway through the install process (Version 22.5.50.7 in my case), the process seems to pause. I've left it for a couple of days at one stage with no success.
My Windows version is 22H2 build 19045.2486.
Screenshot attached.
(Virus scan in progress ...)
DeividA_Intel
Hello Eugenens,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with the Intel® Driver & Support Assistant (Intel® DSA).
1. Which browser are you using?
2. Did you try to reinstall the Intel® Driver & Support Assistant (Intel® DSA)?
3. Just to confirm, you cant update the driver or scan the system due to the update of the tool Is that correct?
Deivid A.
Eugenens
Hello, Deivid A.
1. The Browser is MS Edge.
2. I attempted the reinstall a number of times - a few times with the first download, and a few times with new downloads.
3. As my screenshot indicates, the support assistant freezes up halfway through the install process.
Eugene NS.
DeividA_Intel
Hello Eugenens,
Thanks for the information. Just to confirm, please try the following:
Option 1
  • Open the Add or remove the programs control panel from the Windows Start menu.
  • Locate and select Intel® Driver & Support Assistant in the list of installed applications.
  • Click or tap the Modify button.
  • Accept the User Account Control prompt
  • Click or tap the Repair button to repair your Intel® DSA installation.
Option 2
Option 3
Please let me know if the issue persists.
Deivid A.
Eugenens
Issue solved, thank you. What did the trick was the option 3.
DeividA_Intel
Hello Eugenens,
Thanks for the confirmation. I am glad to know that the issue is fixed, I will proceed to close this thread. However, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
