Processors
13854 Discussions
Intel E3-1285 v6 (CM8067702870937) 1u passive heatsink
GRIFFCOMM
Hi, what heatsink can i use for the above CPU (its going in a 1U chenbro case).
Many Thanks
Emeth_O_Intel
Thank you for contacting Intel Community Support.
I will be more than happy to assist with this information, in order to verify which Heatsink will be supported within your system;
Could you please be so kind and provide me more details about the Intel Server Board you are using and Chassis Model?
As soon as you have those details, please share with me the information and I will proceed with the next step.
Have a wonderful day.
Emeth O.
Intel® Server Specialist
A Contingent Worker at Intel.
GRIFFCOMM
Board = ASROCK RACK E3C236D2I
Chassis = Chenbro RM14204
Emeth_O_Intel
I was doing some research and I was unable to find the correct heatsink for the motherboard and the chassis you are using.
Our best recommendation will be to contact the ASROCK Support in order to verify the correct component for your system.
Emeth O.
GRIFFCOMM
Hi
Lets come at this another way....
What 1U passive heat sinks fit that CPU? i assume the fixing centers fro the socket for the coller are all the same, so ASRock have to adhere to heat sink fixing centers, my goal was to find a 1U passive heat sink for that CPU and use it.
Clearly i can buy a third party, but would prefer an Intel part.
Emeth_O_Intel
I would like to provide you the information about it. Moreover, I am unable to find the heatsink for this processor, and the reason for this is due to the fact that the processor is a TRAY/OEM processor.
The OEM (Original Equipment Manufacturer) for the system needs to provide you those details if you were using an Intel Server Board I could have provide you the heatsinks supported but in your case, you have an ASROCK system.
Emeth O.
