Hello clearname,
Thank you for contacting Intel Communities.
I understand that you want to unlock the advanced options on the Intel® XTU.
In this case, this is only possible if you have an unlocked processor. The processor you have installed on your laptop (Intel® Core™ i7-2670QM Processor) is not an unlocked processor.
You can check the following article for information about Intel® Processor Numbers:
http://www.intel.com/content/www/us/en/processors/processor-numbers.html Intel® Processor Numbers: Laptop, Desktop, and Mobile Device
I hope this information helps.
JC
Hi, I did meanwhile the only correct: I let clean my device and removed all issues, that let me install the utility, but I look in there from time to time. Thank you for your vauable infos. Best regards clearname
