I'm using
11700K
Aorus Z590 Elite AX
current version of XTU 7.3.0.33
not sure why, but its not showing any progress indicators.
please help
Hello funkeemonkee
Please provide the following informaiton:
- Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
- Did it work before?
- Did you make any changes to your system recently?
- Which troubleshooting steps did you try to resolve this problem?
David G
Hi @David_G_Intel
apologies for the delay - here's the file
- Did it work before? - its the first time on this new build
- Did you make any changes to your system recently? - nope
- Which troubleshooting steps did you try to resolve this problem? - you're the first
Not related to the post 100% , but sometimes the XTU shows for my CPU -3.6 Ghz lol
Hello @funkeemonkee
@btimofte please create a new thread with more information to assist you.
David G.
Thank you for the information provided, please follow these steps:
- Uninstall the Intel® Extreme Tuning Utility though "Apps and Features" on Windows.
- Install the latest version of Intel® XTU, version: 7.4.0.26
- Run a benchmark
If it still doesn't work, please share a video of the problem to continue with the investigation and replicate it here in our labs.
David G
David G.
Hi thanks for your reply.
I've got the latest XTU
basically when i Run benchmark.... nothing is showing except the spinning wheel.
attached is the video
https://youtu.be/T9uwT2iDhR0
Thanks for the video and the information provided, we are currently working on this request, updates will be posted on the thread.
David G.
After checking the information provide we noticed the following:
- The RAM is running outside specifications, the maximum frequency allowed is 3200MHz and it's running at 3600MHz currently. Make sure to change the XMP profile or run BIOS defaults to avoid a potential processor failure. Running XMP outside CPU specifications is considered overclocking and it will affect the warranty of the product.
- Do you have any overclocking applications installed? If you do, uninstall them temporarily, it's recommended to use only one at the time so please leave the XTU as the only overclocking capable application on the computer.
- Try to remove the application completely and then install the latest version available. To uninstall follow all the steps from the article How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU)
- Make sure you complete all Windows updates.
David G.
Hi David,
I did all of the following
1. reverted / switched off XMP
2. only intel XTU installed + reinstalled to latest version
same problem. XTU doesn't show anything .
Thank you for the information, we will continue with the investigation and post the updates on this thread.
David G
Hello @funkeemonkee
We tried to replicate this problem with different configurations but we did not get the same result as you, the best option in this case is to do a clean installation of the operating system using a new image of Windows * (not used before).
David G
Hello @funkeemonkee
Did you test the recommended steps? Let us know the outcome.
David G
David G.
