Processors
14539 Discussions
Intel I5-7200U Power consumtion too high Issue
AFrei3
Hi there,
In the past two months , when I'm using software that is graphics demanding such as games or Autocad, the FPS drop for 30 seconds. After that it returns normal for some minutes before the FPS drops again. Running the HWmonitor and logging the sensors, right before this problem occur, the CPU power consumption is behond 15W wich makes it to decrease the cpu clock and the Gpu performance as well. What can i make to decrease this power consumption?
The log is https://drive.google.com/file/d/1FTQJIGjhrYtwf_T5zaomLG9wjpDUhPfZ/view?usp=sharing test2.CSV - Google Drive , and the problem I'm talking about is from line 196 to 206. thank for the support.
Thank you very much for taking the time to reach the Intel Communities Team, AndreFreitas. I will do my best to assist you further.
In order for me to assist you better, please provide me with the .txt file that the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Furthermore, in order to check the health of the processor, please run the and share with us the results.
Antony S.
Hello, AndreFreitas.
I would like to know if you still need assistance. If so, please do not hesitate to reply to this thread.
Antony S.
