Processors
14536 Discussions
Intel IO margin test reported error
RyanGU
Hi all,
We are using Intel IO margin Tool version: 3.1.7 (Request id: 613291 )
And system cannot output margin data, we checked internal record and compared to normal one, the difference is :
Abnormal sequence:  LB_Entry -> LB_Active -> LB_Exit ->RST_ASSERT
Normal sequence: LB_Entry -> LB_Active
CPU&Platform: Ice lake XCC, QVM8, Whitley platform
Would you please check the margin data output failed reason?
Is it caused by LB_Exit?
The screenshot of normal&abnormal sequence has uploaded in attachment.
Ryan
Esteban_D_Intel
Hello RyanGU,
Thank you for your response.
To better assist you, we recommend that you submit your question on the Intel® Developer Zone.
Please register, and create an account so that you can receive further troubleshooting support, and get access to useful documentation.
Intel® Developer Zone - Contact Page
https://software.intel.com/en-us/support
I hope this helps you to get the appropriate support.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
Intel Technical Support Technician
