System Configuration:
CPU: Core i9-9900k
RAM: 32GB DDR4
Motherboard: MSI Z390 Godlike
GPU: 11 GB MSI RTX Geforce 2080 ti
Driver Version: cannot look atm
OS: Windows 10 pro
System BIOS: newest MSI BIOS 1.8
OS Build/Version: Windows 10 PRO 1903
Affected 3rd Party software version: Intel performance maximizer
Issue: I have run the IPM and it found a stable configuration at 4.9 GHz, now it is testing the stability (I assume), but it does this for hours, testing for a minute then rebooting the system. Always tells me I passed the tests at 4.92x GHz. I slowly begin to worry
No troubleshooting yet.
Edit: picture
https://www.instagram.com/p/B3NK-YInc1mpiDcVpqClEUUqcOU-22qxYjecII0/?igshid=18qj8jn4muu2h
MNeib, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, yes, the Intel® Performance Maximizer could take up to 5 hours or more in doing testings and optimizing the system settings.
The reason for that is that the tests bundled with the Intel® Performance Maximizer are designed to provide more robust coverage for a variety of end-user usages and applications. This coverage is tested on a core-by-core basis. It can take a few hours to complete, depending on the number of processor cores and the maximum performance potential of the processor.
Please verify additional details about the application in the following link:
Alberto R.
A Contingent Worker at Intel
MNeib, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
MNeib, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
