Processors
14536 Discussions
Intel Processor Diagnostic Tool, Brand string test fail and temperature monitor fail
ANovi3
Hello!
I have a problem with Intel Processor Diagnostic Tool 64bit 4.1.0.27.w.mp on windows 10 64bit
my configuration
Motherboard Asus P5LD2 (bios last possible v1903 official non-beta)
Processor Pentium D945 SL9QQ
while test this system by IPDT all tests are pass except brand string test that is fail and temperature monitor fail
log from CPU temperature monitor branch:
--- Temperature Test ---
Version 1.0.18.64b.W
Digital sensor is not supported.
..not inside 0xBB --
Temperature not supported.
Test Result - FAIL
Please check your Processor Thermal SolutionExpected Greater than 1 degrees below max
Received 0 degrees below max
Entering run forever
monitoring of the temperature works fine in bios and third party software developer on Windows 10, and the temperature not more then 58C in 100% CPU burn, thermal control (throtling) works fine from 80C (according to AIDA64)
also i have changed all settings in bios that required utility from help paper
actualy i have not much of them:
max cpuid value - disabled
thermal monitor - enabled
c1 control - enabled
speed step - disabled
microcode updation - enabled
execute disable bit - enabled
What does actually that mean, brand string test fail and temperature monitor fail? if the IPDT does not recognise the temperature, so bios (and other soft from Win10) may show the temperature on Mars or Moon but not from CPU?
n_scott_pearson
It's simple; your processor is so old that the tool does not (completely) support its testing.
On your processor, the Brand String test is definitely going to fail (it didn't support a brand string!) and, because your processor had no DTS (digital temperature sensors) on die, it is going to fail the temperature tests.
n_scott_pearson
ANovi3
Thank you! I thought in that direction too, but it is upset that Intel does not explain this (supporting CPU family by each test) in documentation to IPDT
Anyway, thank you very much!
n_scott_pearson
You're welcome - and I agree; they should be doing a quick test to see if a feature is supported before they try to test it. It's not like they don't know how to check...
