I am having an issue with my I7 7700K processor - whenever I do the IPDT test it fails, and yes, I ran it as an administrator. I hope someone can help me with pointing out what's the cause of these issues.
Here are the results of the test:
--- IPDT64 - Revision: 4.1.0.24
--- IPDT64 - Start Time: 21.02.2018. 17:41:51
CPU1
Genuine Intel CPU Test
Module Version: 1.0.14.64b.W
Start Time: Wed Feb 21 17:41:52 2018
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Wed Feb 21 17:41:52 2018
Total Time: seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.17.64b.W
Start Time: Wed Feb 21 17:41:53 2018
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
Intel(R) Core(TM) processor detected..!!..
End Time: Wed Feb 21 17:41:53 2018
CPU1
Cache Test
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
End Time: Wed Feb 21 17:41:54 2018
Total Time: seconds: 1
CPU1
MMXSSE Test
Module Version: 1.0.19.64b.W
Start Time: Wed Feb 21 17:41:54 2018
Test Result - PASS
DetectUtils64 DLL Version - 1.1.2
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Module Version: 1.0.10.64b.W
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
CPU1
Parallel_PrimeNum_i7-7 Test
Module Version: 1.0.0.8
Start Time: 21.02.2018. 17:41:57
Test Result - PASS
Module Math_PrimeNum.exe Completed - Pass
Prime Number Generation Test
Start Time: Wed Feb 21 17:41:58 2018
AVX is supported in your OS
Max AVX supported = AVX2
Test Result - PASS
Operation Per Second: 124182
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Wed Feb 21 17:42:18 2018
Total Time: seconds: 20
End Time: 21.02.2018. 17:42:18
CPU1
Parallel_FP_i7-7 Test
Start Time: 21.02.2018. 17:42:19
Test Result - PASS
Module Math_FP.exe Completed - Pass
Floating Point Test
Module Version: 1.0.16.64b.W
Start Time: Wed Feb 21 17:42:19 2018
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 479.635
Error: 0
--- Floating Point Test Passed!!!---
End Time: Wed Feb 21 17:42:39 2018
Parallel_FP_i7-7
End Time: 21.02.2018. 17:42:39
CPU1
Parallel_Math_i7-7 Test
Start Time: 21.02.2018. 17:42:39
Test Result - PASS
Module AVX.exe Completed - Pass
Module FMA3.exe Completed - Pass
Floating Point Test
Start Time: Wed Feb 21 17:42:39 2018
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.195
Error: 0
End Time: Wed Feb 21 17:44:09 2018
Total Time: seconds: 90
Test Result - PASS
Operation Per Second: 69467
Error: 0
<...Link Copied
Hello Villari,
Thank you for contacting Intel Communities Support.
I will be glad to assist you today.
To provide a detailed answer and understand why the processor is failing the test, please download the Intel® System Support Utility, save the results in your computer and upload them here.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Download Intel® System Support Utility for Windows*
I look forward to hearing from you.
Wanner G.
Hello Villary,
I was reviewing your case to know if you needed any further assistance. It would be great to have basic information about your system to shed light on the issue you are having. Please let me know if you need any further help.
Wanner G.
Hello Villari,
I was looking at the scan you attached and the configured clock speed for your memory is "3000 MHz". According to the memory specifications for yourhttps://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M-Cache-up-to-4_50-GHz Intel® Core™ i7-7700K Processor, the memory supported is DDR4-2133/2400, DDR3L-1333/1600 @ 1.35V. You can try using a supported memory and run the test again.
Also, you can check the BIOS settings to make sure that overclocking is disabled; You might try resetting the BIOS settings to default values as well.
I hope these recommendations shed light on the issue you are having.
Wanner G.
As far as I know I never had any issues overclocking my RAM to 3000Mhz and I was informed that it wouldn't cause any instability with my CPU?
Anyway, I've reset my PC and it seems to have fixed the problem, I now pass the Intep Processor Diagnostic test!
Thank you for replaying to my posts!
