Processors
16137 Discussions
Intel Processor replacement for my Sony Vaio
JesMart
My old Sony VAIO Processor has the following printing;
INTEL NH828a1H9M.  Is this a non removable device. If feasible, what actual replacement should I use to make it work?
Thanks a lot for your advice.
AlHill
You must ask sony what processors are compatible with their bios.  Then, if possible, you "might" be able to upgrade.
[W10 is today's XP ]
pressed_for_time
Valued Contributor II
That part number seems to be part of the chipset, a hub controller of some form. The CPU should be under a heatsink, the exact model of the Sony VAIO might help establish what sort of CPU is fitted.
