How can I tell if this CPU is capable of running Hardware Virtualization. It is in a Dell Studio 540s with 6gb of memory and a 1tb hard drive. The BIOS doesn't have an option to turn it on that I can see. Dell was very vague about it. I need to run vmware with some 64bit virtual machines inside and I'm coming to the conclusion this won't work. It seems odd to me that such a powerful machine wouldn't have this feature. Does anybody know if there might be a hidden option somewhere? Thanks
http://ark.intel.com/VTList.aspx http://ark.intel.com/VTList.aspx
here you can find all CPUs which support Virtualization.
regards
Thanks for the info bloodwurst. It says spec code SLGUR does and SLBSW does not. Any idea where the spec code may be and can I see it without dismantling the machine?
as far as i know, it should be marked on the CPU itself. so if you can´t readout the specifications with software, you have to dismantle your CPU cooler.
Thanks for the link oj. That answered the question, my computer doesn't support hardware virtualization. That is very bad news for me.
no problem. could you mark the question as answered so that its easier for other with similar question to find the answer?
OJ
The S-Spec for the chip is printed on the box if you bought a retail processor.
I am posting this reply within Virtual XP Mode in Widows 7 Pro (64bit) from a Novatech ISYS Ex (PC-1386) which has an Intel Core 2 Quad Q8300 processor. The Novatech website says Virtualization NO but the BIOS says it was enabled so I downloaded Virtual PC from Microsoft and it installed and runs OK. Seems there is a lot of confusion about this processor and what it can and cannot do.
