Hallo, Habe einen i3-3220 3,30GHz 8,00GB 64Bit Betriebssystem und möchte ihn aufrüsten i5-i7 ? hauptplatine ist von Fox Conn Model 2ADA Version 1 , vorweg habe keine Ahnung kann mir da jemand Helfen. Reicht es nur den Prozessor zu tauschen. ? Gruß Carsten
Your board has H61 chipset and Socket 1155 and support for 95W processors. It can be upgraded with processors from any of the following classes:
3rd generation (Sandy Bridge) Core i5-3xxx Quad-Core processors
3rd generation (Sandy Bridge) Core i7-3xxx Quad-Core processors with Hyperthreading
4th generation (Ivy Bridge) Core i5-4xxx Dual Core processors
Almost all of the processors in these classes have reached End-of-Life or End-of-Interactive-Support status and may no longer be available for purchase (unless a store/vendor happens to have old stock on hand). Fact is, current generation processors are from the 7th and 8th generations. I would thus suggest that you upgrade both your processor and your motherboard.
Hope this helps,
Ich werde mich mal umschauen, vielleicht hat ja jemand noch was gebraucht rumstehen und vielen dank . Gruß Carsten
