Processors
14512 Discussions
Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz : Intel Management Engine error
mdasoh
hello.  I am using a Fujitsu Lifebook T901.  It has an Intel 82579LM Gigabit Network Connection (Lewisville) (rev 04).  I want to use DOS in conjunction with Debian GNU/Linux, and so I have been setting up DOS networking with the DIS_PKT.DOS shim and Intel's NDIS driver.  Right about when I tried it first, I got an error booting Intel ME (Management Engine).  It says, SmBIOS table mismatch "error 206," aborting.  It then proceeds to boot.  Not having done this before, I tried pressing ctrl-P to get to the M.E. setup screens.  It wants a password that I don't have.  Please be advised that I don't have a working copy of Windows 10 for this PC.  It's on another hard drive and stopped booting from GRUB2-pc sometime over the last years.  At least it would be a headache to reinstall.  Anyhow, please advise about M.E. password recovery, M.E. firmware updates, and let me know if I'm doing this wrong.  It also seems I tried booting Debian with Xen and the Ethernet hardware stopped working in that configuration after a few boots.
yours,
        - Mdasoh Kyaeppd.
SergioS_Intel
Hello mdasoh,
We appreciate your message.
The error message that you are getting "SmBIOS table mismatch "error 206," aborting" is not related to AMT.
We do recommend contacting your laptop manufacturer and try to install the latest BIOS.
Sergio S.
Maria_R_Intel
Hello mdasoh,
Thank you for posting in the Intel* Community Forums.
I would like to check internally your case to see if we can provide you with assistance. The Intel(R) Core(TM) i5-2520M is discontinued, Intel Customer Service no longer supports inquiries for it. But I will check regarding the Intel Management Engine on this processor.
I will post back on this thread as soon as I have more details about it.
Maria R.
mdasoh
Thank you, Maria, for checking into this case.
SergioS_Intel
Hello mdasoh,
Have you tried the default password "admin"? If you still have problems, you can check the links on how to recover the AMT password here:
https://www.intel.com/content/www/us/en/support/articles/000006328/technologies.html
https://www.intel.com/content/www/us/en/support/articles/000007572/server-products/server-boards.html
You can also check the AMT guide here:
https://www.intel.com/content/dam/www/public/us/en/documents/guides/amt-configuration-utility-user-guide.pdf
Sergio S.
mdasoh
I was able to log into the Management Engine with "admin," and I set something that tells it not to update, which makes it boot faster.  However, it still displays the same error regarding SmBIOS each time it boots.
SergioS_Intel
Hello mdasoh,
Sergio S.
Bharatbhai
Dell Inc. Latitude E6420 bluetooth driver updets link
AlHill
Start a new thread and explain your problem.
[Windows 11 is the new Vista]
