Although Virtualization is enabled in my UEFI BIOS, the Intel Processor Identification Utility says it is not (and indeed virtualization is not working):
Version : 6.7.21.1028
TimeStamp : 2022/01/29 03:24:55
Operating System : Microsoft Windows NT 10.0.19044.0
Number of processors in system: 1
Current processor: 1
Active cores per processor: 6
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
Type : 0
Family : 6
Model : 9E
Stepping : A
Revision: EA
Maximum CPUID Level: 22
L1 Instruction Cache: 6 x 32 KB
L1 Data Cache: 6 x 32 KB
L2 Cache: 6 x 256 KB
L3 Cache: 12 MB
Packaging: LGA1151
Enhanced Intel SpeedStep® Technology: Yes
MMX(TM): Yes
Intel SSE: Yes
Intel SSE2: Yes
Intel SSE3: Yes
Intel SSE4: Yes
Intel AES-NI: Yes
Intel AVX: Yes
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel Hyper-Threading Technology: Yes
Intel 64 Architecture: Yes
Intel virtualization technology: No
Intel vt-x with extended page tables: No
System Graphics: Add-in graphics
Base TDP: 65
Expected Processor Frequency: 3.20 GHz
Reported Processor Frequency: 4.28 GHz
Expected System Bus Frequency: 100 MHz
Reported System Bus Frequency: 100 MHz
Why?
There are a couple of possibilities here,
- Your motherboard manufacturer may have a parameter in their BIOS that says Virtualization is enabled, but they are really not enabling it at the hardware level. This is something to discuss with them.
- You are testing for this capability from within a Virtual Machine (VM) and thus being told that Virtualization is disabled because the VM cannot host a VM Monitor (VMM).
- You are displaying this status using an out-of-date version of the reporting tool. Try something better - like AIDA64 or HWiNFO64.
Hope this helps,
Thanks for your thoughts, Scott. I just download the tool from the Intel website, but I’ll give the other two tools a try anyway. I’ll also try the MB manufacturer, but I don’t expect much help there.
Kind thoughts and thank you for your interest!
Well, I tried your suggestions, Scott, but they have not helped. I should be able to run BlueStacks 5 but cannot. Error is indicating lack of support for VM. Yet I can run BlueStacks 5 on my notebook PC. That PC has an Intel i7-8550U CPU @ 1.80GHz.
I can only suggest that you contact the motherboard manufacturer. They have complete control over the BIOS implementation and what capabilities of the processor are enabled in the runtime environment.
Sorry I have no better suggestion,
