Processors
13536 Discussions
Intel- TSX: why My rtm is acting weird?
Alam__Shariful
I have the following code using Intel-rtm,
rtmCheck.c:
#include <stdio.h>
#include <stdlib.h>
#include <immintrin.h>
int test_otherfunction(int a, int b){
    int c=0;
    for (int i=0; i<1000;i++){
        c=c+a+b;
        //printf("%d\n",c);
    for (int i=0; i<1000000000;i++){
        c=c+a+b;
        //printf("%d\n",c);
    // RTM did Succeeded, but after some tires
        c=c+a+b;
        //printf("%d\n",c);
        c=c+a+b;
        //printf("%d\n",c);
    return 1;
int main(int argc, char *argv[])
    int result=-1;
    unsigned status;
    while(result!=1){
        if ((status = _xbegin()) == _XBEGIN_STARTED) {
            if(test_otherfunction(1,2))
                result=1;
                _xend();
        }else{
            printf("rtmCheck: Transaction failed\n");
            printf("status is %ld\n", status);
	    printf("Trying again ...\n");
            //break;
    printf("rtmCheck : Result is %d\n", result);
    return 0;
 If I compile with the following Makefile1, It always failed. I guess that is expected. And I'm okay with it.
Makefile1
CC=gcc
CFLAGS= -mrtm
rtmCheck: rtmCheck.o
        $(CC) $(CFLAGS) -o rtmCheck rtmCheck.o
clean:
        rm -f *.o rtmCheck
Output:
$./rtmCheck
rtmCheck: Transaction failed status is 0 Trying again ... rtmCheck: Transaction failed status is 0 Trying again ... rtmCheck: Transaction failed status is 0 Trying again ... ........... ...........
But I have another Makefile2. If I compile my code with this(Makefile2) this works every time. just not understanding why?
Makefile2:
CC  := gcc
CFLAGS  :=  -mrtm -Wall -g -MD -O2 -I ../
LDFLAGS := -ltest
tests_files := rtmCheck
all: $(tests_files)
rtmCheck: rtmCheck.o ../libtest/libtest.a
        $(CC) $(CFLAGS) -static $(<) -L../libtest/ $(LDFLAGS) -o $(@)
clean:
        rm -f *.o test *.d $(tests_files)
-include *.d
OutPut:
$./rtmCheck
rtmCheck : Result is 1
Above Make file use some static library. But I'm not using anything from the library. Can someone please tell me why this is happening?
Alam__Shariful
It was the  -O2 flag on the Makefile2. Removing -O2  flag yield the same result.
Alberto_Sykes
Alam__Shariful, Thank you for posting in the Intel® Communities Support.
In order for us to be able to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
what is the model of the Intel® Processor you are using?
Where is the Intel® Processor installed, what is the model of the motherboard?
Could you please provide a description of the Intel® TSX issue and RTM?
Are you a software/hardware developer?
Are you working on a project?
What is the project about?
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello Alam__Shariful, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alam__Shariful
Hi Mr. Albert,
I did not reply to your previous post because as I mentioned in my first reply that I was able to find the reason behind that weird rtm behavior. My rtm was acting weird because of the compilers -o2 optimization flag. It appears that with that optimization flag compiler was solving the value of C without running the code inside rtm. Hence, rtm was always successful regardless the size of the code block.  Changing the type of variable C from int to volatile actually do the trick. So, now the rtm is running as expected.
Alberto_Sykes
Hi Alam__Shariful, Thank you very much for letting us know those details.
No problem at all, perfect, excellent, we are glad to hear that now the RTM is running as expected.
I can see in our database that you submitted another thread about the same matter where basically I asked you the same questions as in here, so I will close this thread and I will continue providing assistance on the new one, if you have further questions, please post them on your new thread:
https://community.intel.com/t5/forums/forumtopicpage/board-id/processors/message-id/47970#M47970
Albert R.
Alam__Shariful
Hi Alberto_R_Intel1,
Sure. Appreciate your help.
Shariful
