Processors
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
14242 Discussions
Intel Turbo Boost Max 3 seems to have broken with the latest windows preview, and Intel has removed all download links.
jpere123
Are the two actions related?
The previous Intel TBM 3.0 drivers error out with the software device being unable to start.
Per core clocking still works, but windows is not properly loading the threads in order
Wanner_G_Intel
Hello jpere123,
Thank you for submitting your question on this Intel® Community.
To better assist you, we would like to have more information about your system.
Please generate a system report with the Intel® System Support Utility (Intel® SSU) and attach it to this thread.
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
Wanner G.
jpere123
Here it is
Wanner_G_Intel
Hello jpere123,
Thank you for attaching the system report.
First, it is worth mentioning that Windows* has native support for Intel® Turbo Boost Max Technology 3.0. However, please try to follow these recommendations:
  • Please load BIOS default settings. After that, make sure Intel® Turbo Boost is enabled in BIOS.
Note: You may need to contact the motherboard manufacturer to obtain step-by-step instructions.
  1. In "Apps and Features", try uninstalling Intel® Turbo Boost Max Technology 3.0 driver.
  2. Also, go to Device Manager > under System Devices > Intel® Turbo Boost Max Technology 3.0.
  3. Right-click on it and uninstall it as well.
  4. After performing these steps, reboot your computer and let Windows* install the latest driver automatically.
If the issue persists, then this issue is most likely related with the Windows* 10 Insider* Preview Build running on your computer. When running a preview build, systems are prone to instability, which may cause Windows* to stop responding while running applications or performing a specific task. It may also have bugs and errors since these versions are not stable. What we can recommend is that you report these issues to Microsoft*.
Wanner G.
MLind34
Wanner_G_Intel
Hello jpere123,
Were you able to review the recommendations provided?
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
jpere123
The point of the insider preview program is to test upcoming versions of windows on end user systems to ensure that it will not affect a large amount of customers when updates go live.
Vendors should also test preview versions to ensure their products will work with upcoming changes.
Intel has removed these drivers from their download page, which i believe is related.
AlHill
As an insider, you report the problems to Microsoft on any nose-ring preview. Microsoft works with the vendor, not you.
Doc
