Hello, everytime I start my PC, I get a message ITBM Driver Not Available Exiting Application. Does anyone know how to fix this?
My specs are:
- CPU: I7-7820x, With Corsair H115I AIO
- MB: Asus ROG Strix x299-e gaming
- RAM: Corsair Dominator DDR4 2x16 3200Mhz, With Corsair dominator platinum airflow (ram cooler)
- GPU: Asus ROG Strix 1080TI OC 11GB
- PSU: Corsair HX1200I
- Fans: 3x AF140L Corsair Fans
- Case: Corsair Carbide Clear 600c inverted atx
- DVD Player: LG BH16NS55
Thanks in advance,
Hugo
Hello HugoValkenburg,
I would like to inform you that the Operating system has a native support for the Intel Turbo Boost Max 2.0 when using Windows 10 * (version equal or greater than 1803).
The operating system supports the Intel® Turbo® Boost Max 2.0 so this feature still working and the computer can still benefit from Intel® Turbo® Boost technology.
That being said, I would like to share with you some steps the message:
Go to Windows Control Panel > Programs > Uninstall a Program, and uninstall the Intel® Turbo Boost Max Technology 2.0 software.
- Open device manager.
- Click in the System devices.
- Right click on Intel® Turbo Boost Max Technology 2.0 Driver.
- Click in properties.
- Go to the driver tab and click uninstall.
- Make sure to select the option to Delete the driver software for this device.
- Check if the message is gone.
As an alternate solution uncheck the “Enable” button in the ITBM User Interface.
See the steps below:
- Go to system tray in your system.
- Right click on the Intel Turbo Boost Max Technology icon.
- Click "Disable"
- No need to reboot.
I hope this helps to answer your concern.
Esteban D.
Intel Technical Support Technician
Hello HugoValkenburg, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Hello HugoValkenburg, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
