Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11680 Discussions
Intel® Turbo Boost Technology in Windows Server 2008?
Community Manager
Intel® Turbo Boost Technology in Windows Server 2008? i need a driver? (i have a i7)
Thx.
DSilv11
Valued Contributor III
Turbo Boost is automatic if enabled by the BIOS and the OS.
You BIOS settings for C states need to be enabled
and the 2008 power preformance settings need to be set to balanced, not preformance. (preformance will lock the CPU's at the rated max speed and prevent the unit from going into turbo boost mode.
Some software that monitors turbo boost may require a driver, but turbo boost does not.
You can see this link for other FAQ on Turbo boost.
http://www.intel.com/support/processors/sb/CS-029908.htm?wapkw=(turbo+boost http://www.intel.com/support/processors/sb/CS-029908.htm?wapkw=(turbo+boost)
