Processors
14513 Discussions
Intel VTx wont be available in I5 7200U if either memory integrity or virtualization based security is enabled
RAJU2529
New Contributor III
Two days before again I checked the features like intel Vtx in cpu intel i5 7200 on the asus vivobook 15 R542UQ-DM153 laptop
I recorded three videos using my laptop.
In first video , I enabled secureboot On , memory integrity OFF in core isolation , Virtualization Based security disabled in registry ,
, then the intel hardware virtualization features is YES ( available )
In second video , I enabled secureboot On , memory integrity ON in core isolation , Virtualization Based security disabled in registry ,
, then the intel hardware virtualization features is NO ( not available )
In third video , I enabled secureboot On , memory integrity ON in core isolation , Virtualization Based security enabled in registry ,
Laptop configuration
Asus Vivobook 15 R542UQ-DM153 ( X542UQ)
secureboot enabled in bios
intel VTx enabled in bios
BIos version X542UQ.302
intel I5 7200U 2.71Ghz
intel HD graphics 620 , driver version 24.20.100.6136
Nvidia Geforce 940MX 2GB GDDR5 , driver version 398.36
Samsung 860 Evo SSD 250GB m.2 2280
Toshibha 1TB HDD
n_scott_pearson
You are making these configuration changes in BIOS Setup? In this case, the problem may be BIOS bug. In this case, you need to contact vendor (Asus) to have them look at their BIOS
RAJU2529
New Contributor III
I am not making changes in BIOS , eventhough ,I never turned off the intel VTx in bios.
I always kept turned ON intel VTx .
I have attached 3 videos , you can see and verify ,
I have configured core isolation memory integration ON , if memory integration ON means intel VTx wont available
Hello raju2529
Thank you for your response.
After performing further research on your issue, we were able to replicate the case scenario that you are experiencing.
We are currently investigating even more to see what triggers this behavior.
We will reach you back as soon as we have news.
This will cause as brief delay between 24 to 72 hour between our responses, I really appreciate your patience.
I hope to hear from you soon.
Diego S.
RAJU2529
New Contributor III
sir . Still my problems not solved. please do research , and give solutions or else I need release patch from Intel or Microsoft
Hello raju2529_inactive,
Thank you for patience.
I have sent you a private message; please review your inbox.
I hope this helps.
Diego S.
