Processors
14516 Discussions
Intel Virtualization i5-4460 not working
Hey community,
since a few days I have trouble with the Intel Virtualization of my i5-4460.
It is not available anymore and I have no possibility to activate it in BIOS because there is no option for that.
I have not changed the hardware and before it worked perfectly, so I have no idea what causes the problems.
I have installed the newest Chipset and Management Engine drivers for my mainboard and also tried different BIOS versions - without success.
I need this feature for VirtualBox, so I would really appreciate your help!
Kind regards,
tobi
Mainboard: MSI H81M-P33
CPU: i5-4460
OS: Win 10 Pro 64-Bit
AlHill
Download, run, and post the results of this tool. Then, an Intel support engineer can assist you.
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html The Intel® Processor Diagnostic Tool
Also, on Windows 10, are you running 1803 or 1809?
Doc
Hey Al,
thanks for your reply.
I have 1803 running and there are no Windows Updates available.
Below is the result of the diagnostic tool, the tests have passed.
--- IPDT64 - Revision: 4.1.0.31
--- IPDT64 - Start Time: 06.11.2018 22:39:46
CPU1
Genuine Intel CPU Test
Module Version: 1.0.16.32b.W
Start Time: Tue Nov 6 22:39:46 2018
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Tue Nov 6 22:39:46 2018
Total Time: seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.20.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Cache Test
Module Version: 1.0.16.64b.W
Start Time: Tue Nov 6 22:39:47 2018
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
End Time: Tue Nov 6 22:39:47 2018
CPU1
MMXSSE Test
Module Version: 1.0.21.64b.W
Test Result - PASS
DetectUtils64 DLL Version - 1.1.2
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Module Version: 1.0.12.64b.W
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 12.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Tue Nov 6 22:39:48 2018
Total Time: seconds: 1
CPU1
Parallel_PrimeNum_i5-4 Test
Module Version: 1.0.0.9
Start Time: 06.11.2018 22:39:48
Test Result - PASS
Module Math_PrimeNum.exe Completed - Pass
Prime Number Generation Test
Module Version: 1.0.19.64b.W
Start Time: Tue Nov 6 22:39:48 2018
AVX is supported in your OS
Max AVX supported = AVX2
Test Result - PASS
Operation Per Second: 127463
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Tue Nov 6 22:40:08 2018
Total Time: seconds: 20
End Time: 06.11.2018 22:40:08
CPU1
Parallel_FP_i5-4 Test
Start Time: 06.11.2018 22:40:08
Test Result - PASS
Module Math_FP.exe Completed - Pass
Floating Point Test
Module Version: 1.0.18.64b.W
Start Time: Tue Nov 6 22:40:08 2018
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 291.33
Error: 0
--- Floating Point Test Passed!!!---
End Time: Tue Nov 6 22:40:28 2018
Parallel_FP_i5-4
End Time: 06.11.2018 22:40:28
CPU1
Parallel_Math_i5-4 Test
Start Time: 06.11.2018 22:40:28
Test Result - PASS
Module AVX.exe Completed - Pass
Module FMA3.exe Completed - Pass
Floating Point Test
Start Time: Tue Nov 6 22:40:28 2018
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.26
Error: 0
End Time: Tue Nov 6 22:41:58 2018
Total Time: seconds: 90
Test Result - PASS
Operation Per Second: 27569
Error: 0
AVX Test</p...
Hi i54460ts: Thank you very much for providing that information.
From our side we can confirm that the processor does support virtualization both VT-x and VT-d:
https://ark.intel.com/products/80817/Intel-Core-i5-4460-Processor-6M-Cache-up-to-3-40-GHz-
In this case the next thing to do will be to get in contact directly with MSI so they can verify the BIOS settings to make sure the virtualizaion feature is enabled.
Alberto R.
Under Contract to Intel Corporation
