Hi.
For some reason Intel XTU CPU Stress test is not working with my 12900K. It just says Passed after literally 1 second. This is happening for me on 2 different version XTU's.
Not much web search results on this one, the only post I found of someone with the exact problem fixed it by using an older version XTU.
Any ideas? I think if I install XTU versions that are too old they wouldn't support the new 12th Gen.
Thanks!
Hello Rothschild
Thank you for posting on the Intel️® communities. Please share with us the following information:
- What version of XTU did you try?
- Did it work properly at any point before?
- Can you share a video of the problem to replicate it?
- What windows version and build do you use?
- Did you overclock the processor at any point before?
- What motherboard model and BIOS do you use?
David G
David G.
David G.
