Processors
14536 Discussions
Intel XTU Signature Validation Failed - i9 9900k, HP Omen Obelisk
rjohn63
Like other folks here I'm having the signature validation failed when trying to run Intel XTU. i've tried uninstalling and deleting the entire XTU directory in Program Files. I've tried both the 6.5.1.371 and 6.5.1.360 versions available on the website.
It used to work on this computer but I don't think I was up to Windows 10 1909 at the time, which I am now.
How can I get XTU running?
Leonardo_C_Intel
Hello rjohn63
Thank you for posting in the Intel Community.
·        I would like to have more details about your system (hardware and software), please run the Intel® System Support Utility for Windows* and attach the system report to look into the issue that you are having.
·        Is the Windows® update the only change that has been done on the system?
Leonardo C.
A Contingent Worker at Intel
rjohn63
I sent you the report in a private message.
I think the other change is the installation of an NVME SSD which is where Windows is now installed (previously it was a mechanical drive with intel optane cache in the m2 slot)
Leonardo_C_Intel
Hello rjohn63
Thank you for the details provided on the issue, allow me to investigate this on my end, I will be posting back as soon as is have an update.
Leonardo C.
Leonardo_C_Intel
Hello rjohn63
Thank you for waiting.
I would like to confirm if you have followed these steps to installed Intel® XTU:
1.     Program Directory: Delete manually all the files from Intel ® Extreme Tuning utility
2.     Delete the program through application and features
3.     Run the installation Utility
4.     Restart the computer
I would also like to confirm if you performed a clean installation of the Operating system (OS) or if you installed a clone image of the OS?
Leonardo C.
rjohn63
Yes that is how I did a clean install of the application.
I did not clone the is, but I did a restore from the official HP restore media.I
Leonardo_C_Intel
Hello rjohn63
Thank you for clarifying those details, allow me to look into the behavior on my end, I will be posting back as soon as I have an update.
Leonardo C.
Leonardo_C_Intel
Hello rjohn63
·        What kind of storage device was on the system prior to the upgrade to the NVME?
·        Have you made any changes to the system BIOS? Is it possible to test the system with default BIOS settings?
·        Do you have a RAID structure? If you do what kind of RIAD structure is?
NOTE: If you have RAID do not load the default BIOS setting to avoid damaging the system RAID structure.
Leonardo C.
rjohn63
1tb Mechanical hard drive with intel optane cache 16gb -- i kept this as a D: drive
Have reset bios to system defaults, the only change is to tell it to boot from the NVMe drive instead of the mechanical one
There is no RAID structure aside from the configuration of the Intel Optane Cache for the mechanical hard drive -- that remains
Removing the nvme drive and clean-restoring the OS (Windows 1903) back to the mechanical allows me to install intel XTU (360) and it is able to launch up.
I installed windows cumulative update 1903 2019-12 and XTU continues to work.
I uninstalled XTU, deleted the folders, reinstalled it (371) to see if a fresh install would break it, but it continues to work.
I installed Windows update 1909 and XTU continues to work.
So far I have not put the NVMe drive back in. The NVMe drive is a WD Black SN750 1TB.
Leonardo_C_Intel
Hello rjohn63
Thank you for the detailed testing that you have performed, let me look into the issue, I will be posting back as soon as possible.
Leonardo C.
Leonardo_C_Intel
Hello rjohn63
Have you tried using a different NVME on the system?
Have you updated the current NVME's firmware on the system? The firmware has to be provided by the MVME manufacturer.
Leonardo C.
Leonardo_C_Intel
Hello rjohn63
Have you been able to test the steps provided?
Leonardo C.
Leonardo_C_Intel
Hello rjohn63
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Leonardo C.
