Although Intel XTU had retained my custom tuning Profile, my Monitoring setup, and my Ratio/Voltage Tuning Mode as Per Core; both Turbo Boost Short Power Max, and Turbo Boost Power Max defaulted to Unlimited with Turbo Boost Time Window maxed at 8 seconds!!! This has happened before but I just happened to check Intel XTU and corrected the Core Active Settings. Intel XTU is only suitable for a constantly monitored hard core gaming computer.
Intel Extreme Tuning Utility, is Unreliable for a home desktop computer. I will try the same tuning using the UEFI-BIOS.
What is your processor model number?
[Windows 11 is the new Vista]
Hello kodo_nosaki,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Have you tried to reinstall the Intel® Extreme Tuning Utility (Intel® XTU)?
3. Can you share any pictures or videos of the issue?
4. Can you share more details about the exact issue?
Deivid A.
Hello kodo_nosaki,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello kodo_nosaki,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
