* I have no other tuning/OCing software installed.
* XTU run correctly on this PC.
* The XTU Service exists, but fails to start.
* The first warning in the XTUCore log states the ACPI driver could not be connected.
* ...and judging by the XtuCore log, a lot of my i7-7700K CPU's settings are unable to be queried. Probably due to the previous issue.
nToss, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, even though you mentioned you already try some troubleshooting steps to try to fix the issue, we recommend to:
-Update the BIOS to the latest version
-Disable memory RAM XMP in the BIOS
-Uninstall Intel® XTU using Apps and Features, please make sure to delete the "Telemetry " folder:
-Try loading BIOS defaults.
-Install the latest Intel® XTU version 7.0.1.4:
https://downloadcenter.intel.com/download/29183/Intel-Extreme-Tuning-Utility-Intel-XTU-
If the problem persists after that, please provide the latest Intel® XTU log files that reflect those changes: using File Explorer: go to folder = C:\ProgramData\Intel\XTU, and zip the Log files or entire folder.
Note: Uncheck "Hide System Files" to see the AppData folder.
Additionally, please provide the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
Albert R.
Done. The last BIOS update for the ASUS Maximus IX Hero was released in 2018.
I'll try that after submitting this post.
I tried a clean reinstall and the issue persisted. The Telemetry folder doesn't exist as was noted in the logs I uploaded.
Ironically, the BIOS defaults make my desktop more unstable and prone to crash.
I have 7.0.1.4 already installed. It's the only version I've tested so far.
AppData is supposed to be ProgramData, yes?
XTU functions properly after using the BIOS default settings.
On the other hand, my PC's overall performance is drastically worse and my fans' speeds now increase sharply with the slightest temperature spike.
Being able to use is not worth the trade-off.
A WatchDog violation caused a green screen of death.
I guess I'll never use XTU ever again.
nToss, Thank you very much for providing that information.
We are sorry to hear that after all the troubleshooting steps done, there are still issues when using the Intel® XTU.
Just to let you know, we always recommend to use the computer under default values at stock configuration to avoid instability on the system. For us to be able to further assist you with this subject, please provide the Intel® XTU logs after the changes done using File Explorer: go to folder = C:\ProgramData\Intel\XTU, and zip the Log files or entire folder.
Albert R.
Hello nToss, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello nToss, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
