I am using latest Intel XTU 6.0.2.2 using X99 chipset and i7-5820k. I set the clocks and voltage and everything works great. I reboot and the settings are reset. I use the same XTU on my Clevo laptop with Z97 chipset and i7-4790k, I set the settings and they stick on reboot. I did install XTU with administrator privileges.
Any ideas?
Hello HTWingNut,
This is an know issue for the newer versions, Intel is currently working in order to fix this issue, as soon as we have an answer we will let you know.
Some XTU users have reported that the older version are working, that they save the settings.
Amy.
Thank you. Where can I find earlier versions to download?
Hi HTWingNut,
Intel removed all the previous versions of Intel® Extreme Tuning Utility from download center. The previous versions of the tool doesn't recognize properly the
latest processors.
Mike C
