Processors
14530 Discussions
Intel Xeon D1500 10GbE LAN configuration - PHY/PCS registers
RMile
for Intel Xeon D1500 family I found only 4 datasheets, in one of them, https://www.intel.com/content/www/us/en/processors/xeon/xeon-d-1500-datasheet-vol-4.html https://www.intel.com/content/www/us/en/processors/xeon/xeon-d-1500-datasheet-vol-4.html there are some information about LAN configuration, but not enough. I need access to PHY/PCS registers of 10GbE interfaces. There is a link to Appendix B, but there is no register map or other access mode (like MDIO). There is also chapter 8.2.2.11.1 "PHY Indirect Data" and 8.2.2.11.2 "PHY Indirect Control" but there is no explanation what is "16bit address" and no information how to access certain PHY registers. Is there available any other document which describes PHY/PCS registers and access method?
Ryszard
Hello RWM
Thank you for joining the community.
To better assist you with information about the Xeon® D families please refer to the following links:
https://www.intel.com/content/www/us/en/products/processors/xeon/d-processors.html https://www.intel.com/content/www/us/en/products/processors/xeon/d-processors.html
https://embedded.communities.intel.com/community/en https://embedded.communities.intel.com/community/en
Leonardo C.
RMile
Hello Leonardo,
unfortunately I have not found information I need.
Under
https://www.intel.com/content/www/us/en/embedded/products/broadwell-de/documentation.html https://www.intel.com/content/www/us/en/embedded/products/broadwell-de/documentation.html
there is some documentation, but many links are broken and no information relevant to my needs (10GbE LAN configuration).
I need comprehensive information about control of 10GbE LAN (configuration registers, setting of loopbacks, PRBS generator/checker etc.). Could you please provide specifications which will cover my needs.
Ryszard
Hello RWM
Thank you for the information provided
Allowed me to share with you that the inquiries on in which you are looking assistance on we encourage you to clarify them with the Intel® Embedded Community, please refer to the following link
https://embedded.communities.intel.com/select-display-name!input.jspa https://embedded.communities.intel.com/select-display-name!input.jspa
Leonardo C.
