Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel Xeon E5-2690 v3 - Max Turbo only 3,1 Ghz?
The Intel ARK states that MAX turbo on the E5-2690 V3 is 3,5 GHZ but when I run CPU-Z on it I only see 3,1 Ghz (100 mhz * 31). I also tried to run Prime on 1 core just to verify and it never when above 3,1Ghz.
Intel Ark Specifications:
http://ark.intel.com/products/81713/Intel-Xeon-Processor-E5-2690-v3-30M-Cache-2_60-GHz Intel® Xeon® Processor E5-2690 v3 (30M Cache, 2.60 GHz) Specifications
Tags (2)
Highlighted
Please test running the Intel(R) Processor Identification Utility and send screen shots of the results: https://downloadcenter.intel.com/download/7838/Intel-Processor-Identification-Utility-Windows-Versio... Download Intel® Processor Identification Utility - Windows* Version
Allan.
Highlighted
Version: 5.40.20151110
Time Stamp: 2016/01/13 17:53:37
Operating System: 6.2-9200-
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 12
Disabled cores per processor: 0
Processor Name: Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz
Type: 0
Family: 6
Model: 3F
Stepping: 2
Revision: 36
Maximum CPUID Level: D
L1 Instruction Cache: 2 x 32 KB
L1 Data Cache: 2 x 32 KB
L2 Cache: 2 x 256 KB
L3 Cache: 30 MB
Packaging: LGA2011
Enhanced Intel SpeedStep(R) Technology: No
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: Yes
Intel(R) AVX: No
Enhanced Halt State: No
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: No
Intel(R) VT-x with Extended Page Tables: No
System Graphics: Add-in Graphics
Base TDP: 135
Expected Processor Frequency: 2.60 GHz
Reported Processor Frequency: 2.60 GHz
Expected System Bus Frequency: 100 MHz
Reported System Bus Frequency: 100 MHz
Highlighted
Have you updated BIOS recently?
Is turbo frequency or turbo boost enabled in BIOS?
Allan.
Highlighted
We have this on 2 different boxes with the same CPU. 1 HP server and 1 Dell server (the only servers we have with the V3 CPU). The bios is latest on both boxes.
Turbo boost is indeed enabled in BIOS
Jonas
Highlighted
if you run memory test on one core you will get 3.5GHz, if you are running prime95 with AVX2 enable then it will stuck at 3.1
Highlighted
Ok I will try memtest.
However, should not the CPU-Z show multiplier 12-35?
