Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12618 Discussions
Intel core i5-8600k voltage
MDelc1
bonjour,
Dans le but d'un overclocking non poussé mais bien réglé,
j'aimerai connaitre les tensions maximales et les tensions poussées mais raisonnable de tous les paramètres du processeur.
-controleur mémoire
-puce pch
N'ayant pas de carte graphique j'aimerai connaitre aussi la valeur de vcore du IGPU (différente du Vcore classique j'imagine car possibilité de réglage)
Intel core i5-8600k
Asus prime Z370-p
GSkill 3.000mHz 15-16-16-35 xmp
Toshiba X300 5To
Merci de vos réponses
Maxence.
Community Manager
Hello FreeStyle
Thank you for joining the community.
I see that you have some concerns about overlooking you Intel® processor, allow me to help you with the inquiries.
Let me share with you that Intel® does not provide assistance with the overclocking of the units, I will also like to share with you the following link https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html for general information about the topic, in addition please bear in mind that the over-clocking process may cause unexpected behavior on the processor and voids the warranty; we encourage the use of the Intel Performance Tuning Protection Plan https://click.intel.com/tuningplan/ https://click.intel.com/tuningplan/ if the unit is used in an overclocking environment.
Leonardo C.
Community Manager
Hello FreeStyle
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
