16810 Discussions
Intel driver 6.5.1.371- performance issue
corti_
After the installation of  following devices updates the computer has a performance problem.
For exemple the windows startup takes more than 5 minutes.
i would like to uninstall that version of driver software is it possible?
The device ACPI\GenuineIntel_-_Intel64_Family_6_Model_142_-_Intel(R)_Core(TM)_i5-8250U_CPU_@_1.60GHz\_1 has been configured.
Driver name: cpu.inf
GUID class: {50127dc3-0f36-415e-a6cc-4cb3be910b65}
Driver date: 04/21/2009
Driver Version: 10.0.19041.546
Driver provider: Microsoft
Driver section: IntelPPM_Inst.NT
Driver Classification: 0xFF0004
Corresponding device ID: ACPI\GenuineIntel_-_Intel64
Priority driver: cpu.inf:ACPI\Processor:00FF2000
Device update: true
Parent device: ACPI_HAL\PNP0C08\0
Driver name: oem20.inf
GUID class: {e2f84ce7-8efa-411c-aa69-97454ca4cb57}
Driver date: 02/05/2021
Driver version: 7.3.0.0
Driver provider: Intel
Driver section: XTUExtension_Install.NT
Driver Classification: 0xFF0000
Corresponding device ID: ACPI\GenuineIntel_-_Intel64_Family_6_Model_142
Priority drivers:
Device update: true
David_G_Intel
Hello  corti_
Thank you for posting on the Intel️® communities.
Please share with us the the Intel® System Support Utility (Intel® SSU) results
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
Intel Customer Support Technician
David_G_Intel
David G.
David_G_Intel
David G.
