The CPU frequency is stuck at 0.78GHz and under full load (while running Prime 95) the CPU usage doesn't go above 34%.
I have tried to reinstall the system (windows 10) with all power setting set to performance and I have update the BIOS but it didn't solve the issue.
You need to check the BIOS configuration. It sounds like you have a limitation being imposed by something there (max clock, max power, etc.)...
All BIOS settings are set to performance with TurboBoost enabled.
My Samsun Laptop has been slow for a year. I am finally doing benchmarking and I see the exact same issue. Intel Core i5-4200U running at 782MHz ! I can't seem to find out why it is being throttled.
Did you solve this ?
This thread is 1.5 years old. Start a new thread.
I had the same issue and i solved by simply remove the battery.
