Good morning all. I am getting a BSOD stop error 0x101 "A clock interrupt was not received on secondary processor within the allocated time interval". I just purchaced this processor about two months ago and am confused as to why this is happening. Below are my computer specs.
ASUS P7P55D-E LX Motherboard
Nvidia GX460 video
8gb Corsair RAM
Windows 7 home premium 64bit
WD 320 gb HDD
Thanks in advance for any help you can give.
Go into the BIOS and make your HD with the OS first in line in the Boot order. Than reboot and see if that cures the problem.
Wow, it seems to be working. I am supprised that such a simple switch would fix that issue. Do you have an explanation?
Thanks again.
During Boot your BIOS looks at everything in the sys. HD DVD and anything else you have hooked up , This takes time If you have your OS Boot drive first in line for the BIOS to look at it just starts faster . So you don't get errors like a slow responding component.
Do your self a favor save your $$$ and get a SSD for the OS and it will start even faster.
If I solved your problem , Mark the thread answered . Glad I could help.
Thanks for the help. I greatly appreciate it. Last question, what is the SSD you referred to?
Oh and I marked you as correct answer.
From what I've read you are on your way to building a real nice SYS . BUT you have to get away from standard Hard drives , At least for the boot Drive , The Very best option is a Intel Solid State Drive 160 Gb is what I would recomend . It's large enough to hold the OS and Lots of programs , Than you get a 1 TB regular drive for storage. These things are so fast you would think that you had a 6 core with 24 GB arm. It's all about IOPS ,( in's and Outs. )
Take that WD320 and get a encloser and use it for back-ups.
On your WEI score whats it reading now ( 5.9 ) My Intel SSD is ( 7.7 ) . with a rotational drive will never get above 5.9 . Not even with TWO Raptors in RAID 1.
Solid State drives hmm? Maybe ill ask Santa for one.
Thanks again for your advice.
Now if I could just fix this Kernal Power Event ID 41 issue, i'd be set.
If you do get one stick with Intel , The read/writes are way under rated My 160GB SSD normaly runs 265 read 120 writes. OCZ and cousair are good SSDs But you can't use the Tool Box . Read up on before you jump on something cheap . Buying a cheaper drive ?? you will regreet.
I read a little about 41 power event , most people say it's caused by hardware. what else do you have hooked up besides the graphics card?? Because what ever it is it's not shutting down quick enough. IE a card reader thumb drive or something like that.???
Here is my full system.
Case: Cooler Master CM 690 II http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
Motherboard: Asus P7P55D-E http://www.newegg.com/Product/Product.aspx?Item=N82E16813131634 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131634
Processor: Intel i5 Quad Core http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067
Power supply: Antec 750 watt http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025
Ram: Corsair 4GB ram kit (got two for a total of 8gb) 2x 2GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820145251 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145251
Video Card: Nvidia 460 GTX http://www.newegg.com/Product/Product.aspx?Item=N82E16814130564 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130564
Optical drive: 22x LG SATA DVD RW http://www.newegg.com/Product/Product.aspx?Item=N82E16827136180 http://www.newegg.com/Product/Product.aspx?Item=N82E16827136180
Hard drive: WD 320 GB SATA hard drive 7200 rpm http://www.newegg.com/Product/Product.aspx?item=N82E16822136098 http://www.newegg.com/Product/Product.aspx?item=N82E16822136098
OS: windows 7 64 bit home premium http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754 http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
I did a quick format on the HDD last night and a fresh install of the OS along with the motherboard tool CD install so thats where i stand now. Next will be the video card driver install when i get home tonight.
I have i5 760 processor and i am using 55 TC mother board with 4 GB RAM with 500 GB Hard Disk.In every morinng i have an arror in my pc Like physical memory error. The pc gets restart and and few restarts it works perfactly i dont knoew i have changed all hardware except cpu .Is it a cpu issue .Pleaswe help me i vary upset
dilip bhatia
