Processors
13568 Discussions
Intel i9-9900k cpu 3.60ghz is overheating at 200f when starting up pc
JesseB
Whenever the pc gets turned on the cpu immediately jumps in temperature to around 180-200f All the other components are colder then room temperature. I checked and re applied new thermal paste but still is overheating.
n_scott_pearson
Super User Retired Employee
That's perfectly normal. This is not overheating. Overheating is where you regularly reach 100c (Tjmax).
JesseB
It pops up on my computer constantly saying it is over heating.
Shivam_Shobhit
Also, do reply with the popup screenshot as well as check if the thermal paste has been applied appropriately.
https://www.hongkiat.com/blog/cool-down-heating-pc/
Also, check with the app's impact and the number of apps that loads at system startup.
Shivam_Shobhit
Shivam_Shobhit
Hey @JesseB
Hope you are doing fine.
As told by @n_scott_pearson  and you can also check the T junction (Max allowed) temp. for Intel® Core™ i9-9900K Processor is 100 deg C so it's normal, no need to worry.
Also, you can try referring to the following links to get your all doubts cleared.
Overheating Symptoms and Troubleshooting for Intel® Boxed Processors
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool( check your processor health by downloading the IPDT tool)
Hope this helps.
Shivam_Shobhit
JesseB
Just replaced the liquid cooler with a noctura fan. temps are now 90f or 32c.
n_scott_pearson
This could mean a couple of things,
  • The liquid Cooler didn't have sufficient thermal mass in the block you mount on the processor.
  • The operation of the liquid cooler's pump and fans were not being properly controlled from the motherboard's fan headers.
  • There was something wrong with the liquid Cooler.
