Processors
16026 Discussions
Intel management engine interface disabling
Dometienne
 causes my system to slow down?
 Hello, I work on a HP Probook,with SSD, and I would like to know if there is a risk by disabling the system device : Intel management engine Interface, because I work independently and this application causes my system slow down ?
AlHill
The ME does not cause your system to slow down.  You have some other issue.
'Doc (not an Intel employee or contractor)
[If you find any Intel driver you might need, download and save it now.]
Dometienne
Hello Alhill, you didn't answer my question . I asked if i could disable Intel management engine interface without incurring any issue .
Mike_Intel
Hello Dometienne,
Disabling the Intel Management Engine (IME) can be done in different ways depending on the system configuration and the manufacturer's implementation. The process can also be complex and can potentially impact the functionality of some hardware and software components.
Here are some general steps to disable IME, however it's important to note that the exact process may vary depending on your system:
  1. Go to Device Manager.
  2. Under System Devicesright click Intel Management Engine and click Disable Device.
You may also check the system documentation provided by the HP, as they may have specific instructions on how to disable IME. Kindly Contact HP for further assistance.
Michael L.
