Processors
14512 Discussions
Intel processor diagnostic tool - question about temperature
SLitw
Hi. Have question. If temperature of processor reach 100C test just will fail and stop right? Or even if reach max temperature it will not fail?
Hello frusciante23,
I understand that you would like to know whether the Intel ® Processor Diagnostic tool will show "fail" if the processor reaches 100C.
Regarding this, it depends on the max temperature allowed by the processor, when higher than the maximum allowed it will actually show as fail, however if it is within specs it will not show as a failure.
David V
SLitw
I mean when temps reach 1C ( 99C )below max test will show fail. Is this normal?
And there is a message:"Please check your thermal solution"
Hello frusciante23,
Thank you for your response,
According to what you mention, it seems to be that there is a problem with the fan (thermal solution) that is being used. It is advised to check that it is properly seated on the processor. Change the thermal paste of it as well and after that is done retry the test.
It seems that the processor's temperatures are going a little too high and that is the reason why that message showed.
David V
Hello frusciante23,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
