Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12584 Discussions
Internal Parity Whea Logger 19
SLitw
Hello. Today i was checking for no reason event logs and find, WHEA-LOGGER 19 Internal Parity warnings,
My pc:
9900K 5G OC PROFILE
2x16GB DDR4 3000MHZ GSKILL
Asus Prime Z390-A
Corsair 850RmX
Pc is rock stable. But that warnings can pop out of the blue.
Also get this on new bios and older. Sometimes WHEA LOGGER 19 INternal parity will pop up. Like 2 warnings of each day. Should i worry?
I played new Metro 10 hours and after i check events and got this:
https://i.postimg.cc/xjJ6kPTm/ie.jpg
Currently using Windows 10 the newest build. Newest nvidia drivers.
No have problems with crashing,bsods. No performance issues.
So ignore this or just revert back oc or xmp?
Wanner_G_Intel
Hello SLitw, Applying overclocking profiles or overclocking the main components of your system can produce unpredictable results or system instabilities. We recommend running your system using default BIOS values and within specifications (e.g Memory; GPU) For more information about this processor or the memory recommended, you can also refer to ark.intel.com > Intel® Core™ i9-9900K Processor. If you consider that you would like to continue using overclocking profiles, we recommend contacting your motherboard manufacturer for more information and instructions. Additionally, you can visit the following support web link about overclocking Intel® Processors. Overclocking Intel® Processors https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html The warnings you are receiving may be related to hardware, but this behavior is not predictable when altering the clock frequency or voltage. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
SLitw
Hello. So yes my cpu is overclocked due to Asus 5G OC PROFILE in UEFI. I changed only manually voltage to 1.31v and no wheas. So stay with that setting?
Wanner_G_Intel
Hello SLitw, For questions related to overclocking, BIOS settings or features, we recommend contacting your motherboard manufacturer and visiting the web links recommended on this thread. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
