However, during Intel XTU's stress test, it quickly climbs up to 100C an remains over there. On examination, I found that not all P cores are throttling, 4 cores stayed at around 92C, while other cores touched 100C.
Kindly provide your perspective on this.
Hello SatishS,
During stress tests like Intel XTU, it’s common for temperatures to spike to the maximum operating temperature, which for the i7-14700K is 100°C1. This is the T-junction temperature, meaning the maximum temperature at which the CPU is designed to operate safely. Normal Operation (35-45°C): This is a typical temperature range for idle or light usage. It indicates that your cooling solution is effective during low-load scenarios. Gaming (up to 85°C): Gaming can be quite demanding on the CPU, so temperatures in the mid-80s are not unusual. This is still within safe operating limits for your processor. Core Temperature Variations: It’s interesting that not all P-cores are throttling and some stay around 92°C while others hit 100°C. This could be due to variations in cooling efficiency across different parts of the CPU or differences in workload distribution among the cores.
My perspective and recommendations, Cooling Solution: Ensure your cooling system (e.g., fans, liquid cooling) is functioning optimally. Sometimes, reapplying thermal paste or adjusting fan curves can help manage temperatures better. Airflow: Check your PC case for adequate airflow. Proper intake and exhaust can significantly impact cooling performance. Stress Testing: While stress tests push your CPU to its limits, they don’t represent typical usage scenarios. If your CPU only hits 100°C during these tests and not during regular use, it’s generally not a cause for concern. I attached article that contains useful information. Kindly check it below.
Information about Temperature for Intel® Processors
Randy T.
Hello SatishS,
I hope you had the opportunity to review the information I posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently.
Randy T
Thanks for your inputs. I happened to change thermal paste. Old one was almost gone and scrapped towards the sides.
Now there temperature even during stress test has dropped to 80 C to 88 C and thermal throttling has stopped.
Hello SatishS,
Thank you for your update. I'm glad to hear that changing the thermal paste resolved the issue and that the temperatures have dropped to a more manageable range, stopping the thermal throttling.
As the issue is now resolved, I will go ahead and close this inquiry.
Should you encounter any further issues or need additional assistance please submit a new question, as this thread will no longer be monitored.
Randy T
