Processors
13176 Discussions
Is it normal to have i7-8550U with two cores?
liuxueliang
Hello, All,
    My laptop is thinkpad t480s, and I find it slower and slower recently. After a carefully check, I find that in task manager, the cpu i7-8550u is with 2 cores and 4 threads. But officially I find the cpu should have 4 cores and 8 threads.
I check it with lenovo but they suggest to reinstall win10. It is not a good solution. Is there any tools or configuration to solve the problem? thanks in advance.
megan3000
Valued Contributor I
Check if the number of cores enabled is limited in MSConfig... Check this link for reference...
https://www.alphr.com/enable-all-cores-windows/
There is a checkbox "Number of processors". When it is unchecked, it means no limit is in place, therefore, the system should use all the cores depending on the workload demand... Otherwise, I would think there could be a BIOS setting that might be also restricting the number of cores active (in which case, you need to check the BIOS user's manual or ask Lenovo for help...)
