Processors
16413 Discussions
Is my i7-7700k overheating?
radiobiggs
Hey Intel community -
I just upgraded my Intel i5-7400 for an i7-7700k...super excited about the additional processing power!  However...the cores seem to be running pretty hot.  I used HWMonitor and Cinebench to check out the temperatures and they are peaking at around 100-C!
My question is this: is this normal for this processor?  I've ready that the 7th gen i7's run hot.
(Additional info:  I bought the CPU used and I'm still using the stock CPU fan.  This was also my first time swapping out a CPU, so hoping I did it right.)
Thanks so much for the help!
AlHill
Do you know for certain that your motherboard bios supports the new processor?  how about the cooling system?
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
AlHill
Additional information.   Compare the two processors:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=97147,97129
As you can see, the i7-7700K does no come with a cooling fan.  You must provide your own cooling solution.  Using the stock fan for your i5-7400 will be inadequate.
Also, just because the i7-7700K fits the socket, it does not mean it is supported by your motherboard bios.  You must verify if this processor is supported.  And, the bios should be updated to the latest.  Fan control is provided by your motherboard bios.
And, adequate ventilation is always a must.
radiobiggs
Oh, and yes I have updated to the latest BIOS version.
AlHill
"Is 100c way too hot?"   Yes, it is too hot.
A site like tom's hardware has some suggestions:
https://forums.tomshardware.com/threads/best-fan-cooler-for-i7-7700k.3046635/
radiobiggs
Success!  I bought/installed a new fan cooling system and the temps have dropped at least 10 degrees when idle, and 20 at peak processing power.  Here's what I installed:
https://www.amazon.com/dp/B00JQ2YDCY?tag=pcbuilds101-20
Thanks again for your help in cooling off my system!
AlHill
Cool (pun intended).  Glad you have it working.
radiobiggs
Hi Doc -
Please find the system scan text file attached.
To answer your question, yes, I believe my motherboard (MSI B250M Bazooka) supports the i7-7700k.  Here's the link:  https://www.msi.com/Motherboard/B250M-BAZOOKA.html
Is 100c way too hot?  What could happen?  Is there a cooling system that you would recommend?
Thanks again for your help!
(Virus scan in progress ...)
AndrewG_Intel
Hello @radiobiggs
We are glad to know that the overheating issue is solved after installing a new cooling solution. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you @AlHill for the support.
Andrew G.
